airpod battery problem
Continuing the discussion from GoldenChaos-BTT Support and Feedback Thread:
hello your preset is wonderful! but i have a one problem..
my airpod is 2 generation. your airpod battery shows like this...
why this happen??
He has the same issue with my AirPods widget with setup UI.
(he PMd me)
Interesting - I will confirm this on my end and release a fix. I’m guessing something changed about the output of the Bluetooth shell script.
I should have time tomorrow and this weekend to put out a new experimental version :grimacing:
Hello, I'm new here. Just recently bought the new macbook & newer AirPods. I have tried all the versions that have been put on this website for the AirPods battery indicator widget and seem to run into the same problem with no solutions in sight. I'm assuming it's something to do with the newer AirPods as my older ones seem to connect correctly, but the AirPods 2 only show battery indicator of the Left side, else just says "false".
The name does not seem to be a conflict as they're copied over universally like a past user suggested. ("Danes AirPods")
