Skiba
September 29, 2023, 5:25pm
1
After some time of using Mac there is popup appearing and, with every click on [Allow] it appears again and again...
"BetterTouchTool.app" would like to access data from other apps.
Keeping app data separate makes it easier to manage your privacy and security.
What can I do about it?
Type of Mac: Mac book Air m2
macOS version: Sonoma 14
BetterTouchTool version: constant popup prevents me from accessin BTT to check the version, but I t is the latest one
this is a new permission (which still seems to be buggy) in Sonoma, you can workaround it by giving the „Full Disk Access“ permission to BetterTouchTool in System Settings-> Privacy & Security.
Can you think of a script in BTT that accesses a file from another app?
I had the same problem. Full disk access worked for me
I have the exact same error. MacBook air M2 2022
Skiba
October 11, 2023, 5:26pm
5
Thanks for Solution and explanation
_shlomo
November 18, 2023, 6:46pm
6
For me it was this trigger that caused the permission message to pop up every time I opened the software
