Note:
After the "Import License," the system will display the phrase "bettertouchtool is currently disabled (see below)" after a certain period of time, restricting the use of the BetterTouch Tool.
In particular, it seems to happen often after the system's sleep, and every time we do "Import License" again.
I deleted and reinstalled everything related to hegenberg from the system, but the same problem occurs (find / -name "hegenberg")
I am attaching the BetterTouchToolDebug after compressing it.
BetterTouch Tool does not work on all devices.
- Type of Mac: Intel Mac (2019)
- macOS version: macOS Sonoma (14.3.1)
- BetterTouchTool version: (please post the exact version - not just "the latest one") 4.402
