I have a set up, where two finger click on the mb trackpad, does a middle wheel click, and three fingers does a right click. Pretty normal, i guess i'm not the only one who does it like that.
The thing is that after a couple of minutes, when i click with two fingers, the link that i wanted to open in a new tabs it opens, but it also does a single click. So i end up with two tabs with the same content because it performed a singles click and a middle click. The only thing i can do to fix it is to restart it, and it keeps working for another couple of minutes, then it has the same behavior.
- Type of Mac: Macbook pro with Force Touch
- macOS version: Mojave 10.14.1
- BetterTouchTool version: 2660
