Advanced Trigger Conditions per Folder?
I wonder how people configure multiple triggers' ATCs.
I asked this years ago and got 0 attention, yet I'm still wondering.
I hope I'm not the only one who is clicking around every f single trigger and repeating the same thing.
Since you can't use some condition for CAGs, and you can't configure per folder, you have to edit them per trigger, am I correct? Can you copy and paste only ATCs?
I tried to copy the triggers and paste them into a text editor, and then edit the JSON to add ATCs for the triggers. After that, I pasted it back into BTT, but it didn't recognize it.
https://docs.folivora.ai/docs/1400_conditions.html
having ATC's per folder is a good idea that should be relatively easy to implement. I'll give it a shot soon. An option to only copy the conditions is also a good idea.
In the exported format the textual representation is read-only (and for validation), the actual condition is exported in binary format. Unfortunately this is hard to change because the system frameworks have a hard time parsing some of the condition format strings - especially if they contain special characters.
Good to know that!
Thanks for paying attention to this!
I’m migrating a bunch of things from CAGs to ATCs, as the ATCs seem to work more consistently for me.
In doing that, I’m also struggling with managing ATCs for multiple Triggers. Setting them up is one thing, but the real challenge comes when I want to change anything later.
Per folder ATCs would be amazing.
Copying and then pasting to multiple selected Triggers would be pretty good too.
