Hi Andreas,
it seems that the Advanced Trigger Condition "Trigger while mouse over Dock" is not saved.
See video:
Video was taken on BTT 6.802 but still reproduceable with 6.805.
Best regards,
Volker
Hi Andreas,
See video:
Best regards,
Volker
It seems to be a display issue, the correct value seems to be saved and applied but the dropdown is not showing it. Will be fixed with next build.
Hi Andreas,
Something similar is happening to me. I'm setting up separate actions for my MX Master 3 and my MX Creative Console, with different actions depending on which device triggers them. When I set the Vendor and Product IDs under "Only On Logitech Mouse Model," the value does get written to the config (I can see it in the JSON as "BTTAdditionalConfiguration" : "Vendor: 0x046D, Product: 0xB023"), but it doesn't actually filter the trigger. Both devices fire the same action regardless of which one is set in the condition.
So unlike the "Trigger while mouse over Dock" case, this doesn't look like a display-only issue on my end, the value is saved correctly but not being enforced at trigger time.
BTT version: 6.825
macOS version: 26.7
Happy to send debug logs if that helps.
