- Create a widget "Now Playing Widget"
- Set Predefined Action: "Run Apple Script (async in background)"
- Paste code:
# Clicks count
set clicks to get_number_variable "MusicPlayerAction"
end tell
# First click
if clicks as string is "missing value" then
set clicks to 0
end if
# Increase the number of clicks per unit
set clicks to clicks + 1
tell application "BetterTouchTool" to set_number_variable "MusicPlayerAction" to clicks
# Waiting
delay 1.2
# Current number of clicks
set now_clicks to get_number_variable "MusicPlayerAction"
end tell
# Action
if now_clicks as number is clicks then
tell application "BetterTouchTool" to set_number_variable "MusicPlayerAction" to 0
# Actions
if clicks as number is 1 then
# Next track
trigger_action "{\"BTTPredefinedActionType\" : 27}"
else if clicks as number is 2 then
# Play/Pause
trigger_action "{\"BTTPredefinedActionType\" : 23}"
else if clicks as number is 3 then
# Prev. track
trigger_action "{\"BTTPredefinedActionType\" : 26}"
end if
end tell
end if
- 1 click - Next track
- 2 clicks - Play/Pause
- 3 clicks - Prev. track
