Advanced Conditions Not Preventing Trigger Fire
@Andreas_Hegenberg Are Advanced Conditions — when set on the Trigger Level — supposed to:
  • prevent a Trigger from firing — if the conditions are false? Or...
  • prevent a Trigger's Actions from firing — if the conditions are false? Or...
  • Both?
I have a Trackpad Trigger (single finger, double tap), set with the below Advanced Conditions. In the Recently Used pane, I see:
  • This Trigger fires any time I do a double tap.
  • But the actions only fire, if the conditions are met.
Is this normal behavior?
Or should the entire trigger not fire if the conditions are false?
Advanced Conditions set on Trigger:
this is expected, have a look here Trigger Conditions & Conditional Activation Groups · GitBook
Thank you sir!
