Hello Andreas,
can you add a trigger when BTT remote is entered / leaved?
I have activated the Hot Corners in macOS. When I use BTT-Remote and the iPhone jumps to Landscape Orientation, the mouse pointer is always moved to the upper right corner and the stored action (in my case Mission Control) is activated. This is very annoying and no setting I could prevent it so far.
With the trigger I could turn off the Hot Corners temporarily.
Thanks a lot!
Dirk
