Add "right click" as a trigger to disabled snap areas while moving a window
I love the snap areas and I come from using Fancyzones on Windows which has the "right click" as one of the triggers for enabling or disabling the snap areas while moving a window.
Not to necro this (okay I guess that's a lie), but I'd love this, too. I currently use option, which is fine (and actually, I'd like to keep using it for when I'm on trackpad-only) but "hold right click while dragging" is such an ergonomic choice -- doesn't do anything in that context otherwise, zero impact if you do it accidentally, and keeps the action totally one-handed. It could even be the default behavior, and people probably wouldn't even notice.
I ended up tossing together a Karabiner rule ("Complex Modification") that did this -- simulates the hold-and-release of opt in a way that makes M1 (held) -> M2 (held) trigger snap areas in BTT perfectly. I already run Karabiner, as I suspect many BTT users do, so it works well for me, but it'd be great to have this built-in.
For anyone who needs it: (Obviously this is written for "opt" as your snap area visibility trigger.)
    "description": "Hold M1, then hold M2 → hold Option (M2 suppressed)",
    "manipulators": [
            "from": {
                "modifiers": { "optional": ["any"] },
                "pointing_button": "button1"
            "to": [
                    "set_variable": {
                        "name": "m1_held",
                        "value": 1
                { "pointing_button": "button1" }
            "to_after_key_up": [
                    "set_variable": {
                        "name": "m1_held",
                        "value": 0
            "type": "basic"
            "conditions": [
                    "name": "m1_held",
                    "type": "variable_if",
                    "value": 1
                    "bundle_identifiers": [
                        "^com\\.example\\.AppToDisable$"
                    "type": "frontmost_application_unless"
            "from": {
                "pointing_button": "button2"
            "to": [{ "key_code": "left_option" }],
            "type": "basic"
