I would like to request a feature to add an option to optionally exclude or include the "Shift" modifier for the hyper key. This would enable more flexibility in creating unique key combinations.
For example, I could map "Hyper Key + S" to open vscode and "Hyper Key + Shift + S" to open Apple Notes. This would expand the number of key combinations available to users.
Not really. Let's say the solution was never particularly emphasized. For some time now, any physical modifier can press and release any virtual one. This triggers shortcuts that have been set up in BTT but also those of another app.
If Caps Lock is mapped to (right) control, you should be able to (virtually) add any other modifiers you want. Use a Key Sequence.
That's correct, it can already be done However it currently requires some manual setup / remapping. Maybe I can quickly create a preset that does it with the current versions already.
Cool. And by “any” do you really mean “any”? So, if “f” is pressed and “j” is also pressed, then BTT does something? Without the “f” and “j” being typed?
yes, but it will exact the same way as currently with capslock => the original key would stop working. So it will be possible but not really be usable with most keys
it really is only intended to be used with keys you don't regularly need. Maybe some F keys or maybe the right modifier keys (for people using hyper key outside of BTT).
