Add exclude modifier conditon in trackpad triggers
now I've set pinch in and pinch out to some function, but I wish only when I not press command, to do those function, if I'm pressing command, the pinchin and pinchout still do the default macos zoom behaviour, can this done in current btt version?
You should be able to include the modifiers you want for each trackpad gesture.
hi ,sorry I edited my question, i mean only trigger when I not press command, if press command, I wish pinchout and pinching still do macos default zoom function
I'm not sure whether this works, but you can try to assign the "Use Apple Default or Do Nothing" action to the cmd+pinch
