"Activate Previous Window" doesnt apply for all spaces
The "Activate Previous Window" function only accesses current space windows so doesnt shift to previous window of other space. Please do fix this!
@Andreas_Hegenberg any fix for this?
no, this is complicated, I’ll check whether it can be done but it will take a while
Sure! but it IS possible though. An app called 1piece which is essentially a app switcher app like alt-tab has this function to press modifier key twice to switch to previous window and it works for all spaces
ah yes, it also works with BTT's window switcher (predefined action "Show Window Switcher For All Apps"). Then it will be an easy addon! I'm away for the weekend but will add it on Monday
Thank you!
