“Activate/Bring to Front Window Under Cursor” action doesn’t work for Chrome “installed apps”
When hovering a Chrome "installed app", the “Activate/Bring to Front Window Under Cursor” action doesn't do anything.
Repro steps:
  • Create a BTT keyboard shortcut that starts with the “Activate/Bring to Front Window Under Cursor” action.
  • Log in at https://drive.google.com/drive/home
  • Click top-right Chrome "hamburger" menu, “Cast, Save, and Share”, “Install Google Drive…”
  • Open the “Google Drive” app.
  • Click on a different app to give it focus in MacOS.
  • Hover the mouse over the Google Drive app.
  • Activate the BTT shortcut.
Expected: The Google Drive app gets focus.
Actual: No change to focus.
Note that the shortcut works as expected for all the normal Chrome windows and other apps I tried (Notes, System Settings, Calculator, Preview, iTerm2, Spotify, Outlook).
  • Type of Mac: MacBook Pro, 16-inch, Nov 2023, M3 Pro, 36GB
  • macOS version: 15.4
  • BetterTouchTool version: Repros on versions 5.294 and 5.296.
I've tested this with MS Edge and it working. If you have MS Edge can you try with it?
macOS: 15.3.2 (24D81)
BTT: Version: 5.294 (2025033105)
