Actions to move winow to next monitor not working
These three actions stopped working sometime during the last few alpha updates. I've been lazy to report it and hoping it got fixed silently. But I think it's been about a month now since none of these work.
  • Type of Mac: MBA
  • macOS version: 15.1.1
  • BetterTouchTool version: 4.940
I've just tested all 3 actions, and they work, if I use a shortcut. Main difference is that I use macOS Sonoma 14.7.1 (23H222), not sure if this could be the reason.
BTT Version: 4.947
Hi, any update on this?
I tried to reproduce it but they work as intended on all of my test systems.
Do they not do anything on your machine?
Yes, nothing happens except for the HUD I enabled to test if the action was triggering at all. Same behaviour for both actions — one set as a trackpad gesture, another as a keyboard hotkey.
Do other window resizing actions still work?
Yes, practically all of them — I use halves, thirds, center, quarters, etc. but all on the same screen. They work perfectly on either display.
Weird :-/ has anything about your display setup changed recently?
Nope. Only macOS updated to v15. Even the screen resolutions are exactly the same, so can't think of what might have changed. I added 2 stream decks to my setup but I don't think that'd have affected this (one strem deck has all my window management shortcuts)
Stream Deck should not make a difference. Weird, I'll add some logs for these actions to the next version, maybe they'll show something
Cool. Let me know whenever you get around to doing that and I'll email you the logs.
