When in BTT configuration, if you select "BTT Remote", then go to an app to add a trigger, you can add a trigger, but the action panel is not showing up.
In my case, I have to go to another option (From "BTT Remote" to "Touch Bar" for example) where actions are configured, so that the action panel shows up again.
BTT Remote.
- Type of Mac: iMac
- macOS version: 10.15.4
- BetterTouchTool version: 3.365 (1582)
