Accidentally reset my preset
I accidentally reset my preset, I thought I've backup but no.
I have a Time-machine back up, is there any way to recall it?
If you have a time machine backup you can restore this folder: ~/Library/Application Support/BetterTouchTool (make sure to include the ~)
BTT also creates auto backups regularly, you can restore them here:
Totally solved my problem, really thanks a lot!!
