I'm having an issue with BetterTouchTool where I often accidentally trigger a right-click when using scroll wheel gestures. My current trigger is set to "hold the scroll wheel and scroll down" to switch to the next tab.
However, I find that when I attempt to use this gesture, it frequently registers as a right-click instead, disrupting my workflow. I was wondering if there might be a way to improve the sensitivity or configuration of the scroll wheel gesture to prevent these accidental right-clicks from occurring.
I'd appreciate any suggestions or solutions that fellow BetterTouchTool users might have encountered while setting up similar scroll wheel gestures. Is there a specific setting I should adjust, or perhaps an alternative way to set up the gesture that would be less prone to accidental triggers?
Thank you in advance for your help!
