Getting a prompt saying that accessibility permission are not enabled for better touch tool. It is on though. Tried turning it off an on. Tried removing the better touch tool entry and manually putting it back. Tried restarting (multiple times this has been happening for weeks now). Tried resetting accessibility permissions in terminal ("sudo tccutil reset Accessibility"). Nothing works. Only thing that works is restarting better touch tool from menu bar. All features have continued to work all the time though so I suspect it's a false alarm.
- Type Macbook Air M1:
- macOS Sonoma 14.4
- BetterTouchTool version: 4.460 Alpha (btw is there no way automatically install alphas in the background?)
