Would it be possible to get the accelerometer data from Siri Remote?
Thank you in advance.
that'd be awesome indeed!
Unfortunately I haven't found a way to access that data ;-(
is it possible to get the x, y of the finder on the touch pad (I see this data in the live update)?
Thank you for the reply.
Yes, but what would you want to do with it?
Pass them into unity.
I think you would need to write your own "connector" to do this because there is no performant way in BTT to forward such data to other apps.
Accessing the data is however quite complicated and requires the use of private apple frameworks, so not sure if you want to go there...
Ah I see, thank you. I will need to think of another hack.
