Absolute position control for Trigger on Floating Menu … moved? missing?
Hi. Did the Position section containing the drop-down control for either "absolute” that allowed spacing by x,y offsets or “follow setting for Floating Menu” get moved? I am almost sure this was in the Floating Menu Configuration column on a “General” tab. That tab no longer shows for me (the tabs have been changed to, it appears, better fit with the system-wide (?) light/dark mode setting.
I use one of the auto-position settings for my Floating Menus, and have several small Triggers related to the Menu itself that I position absolutely relative to the Menu.
TY.
ah thanks for reporting, I accidentally hid that section in the current BTT. I'll make it visible again in the next alpha later today
TY!
Much missed. Restarted, re-booted, checked for updates, checked this forum, shut down and restarted, slept on it, Googled, opened every configuration section, and concluded, “I’m losing my mind.”
All good!
6.035 should add it back:
Confirmed!
Thank you for the speedy answer, update, and resolution …
… as well as for your fast pace of development.
