Use case:
I work in 2 different setups:
- At my workstation where I have a large monitor.
- On the bed, chair, etc. where I just use my laptop.
I'd like the same keyboard shortcuts (fn+left, fn+right) to work differently depending on the setup:
- On the monitor, I'd like to map fn+left to take up 1/6 of the left side of the screen
- Since my laptop is smaller, I'd like to map fn+left to take up 1/2 of the left side of the screen
Same goes for the right side, then I'd use modifiers to move it to the 2nd of 6 areas.
