Ability to animate a Floating Menu becoming invisible (hidden)
While you can animate a Floating Menu becoming visible, it seems you can't animate it becoming invisible. This ability would, for example, make app switcher/launcher type Floating Menus able to mimic the short fade-out animation the native macOS Application Switcher does after the ⌘ key is released.
