A small problem that is annoying
@Andreas_Hegenberg It's a small problem, but one that I find increasingly stressful, which is why I'm addressing it here :slightly_smiling_face:
I'm triggering something. Look in “Recently Used” to see what the trigger is called. Then I switch to the right app and search for the name. BTT finds what I'm looking for and highlights the trigger. I delete the search and scroll to the highlighted trigger. If I now click on the trigger, everything moves. The trigger I am looking for is then either much further up or further down in the list.
I don't know if you understand what I mean :rofl:, but if you do could you change that? :pray:
I'll have a look!
Sorry to bother you again ... but it's driving me crazy.
Könntest du das bei Gelegenheit beheben ... oder du besuchst mich bald mal in der Klapsmühle :crazy_face: Deine Entscheidung :innocent:
