A problem with Key Sequences
@Andreas_Hegenberg I would be very happy if you could solve this.
I have two key sequences (KS1 / KS2 below)
  • KS1 just types a capital “I”, with shift, like you would normally do it.
  • KS2 triggers a different action
This actually works quite well. But in 20% of the cases KS1 types two “I” when typing fast, even if I keep the pause between the keystrokes as short as possible (0.07s)
For example, “IIhr” is typed instead of “Ihr”.
Do you think you can fix this? Many thanks in advance.
KS1
KS2
