Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app's "Crash Reports" section.
Updated to 6.009 (forgot what last version is, I might have updated CTT in Dec 2025 previously and it was working), Launch and 100% CPU not responding in Activity Monitor. Restart laptop no help.
100% cpu usage usually means something is triggering itself endlessly. Sometimes it is also an issue with the experimental Dropox & iCloud sync if you have that enabled.
You can try quitting BTT and running this terminal command to enable safe mode:
Your 100% cpu usage was caused by a weird database corruption. There is some trigger in your BTT database that has itself as parent relation. I'm not sure how that could happen, but I have added a check to prevent issues with that now.
