I set 3 finger double tap in BTT to execute apple script,
in macOS trackpad options , if I don't select "Look p & data detectors"
the 3 finger double tap not working!'
but if I select this , when I select some text,double tap will open dictionary.app
I've enabled 3 finger dragging in accessbility
- Type of Mac: m2 MacBook air.
- macOS version: Monterey 12.6
3.936
