BTT newbie here, I'm coming from MagicPrefs and I'm trying BTT on Catalina.
I'm trying to get the same behaviour that I had in MagicPrefs for the 3 fingers middle click.
I use it a lot especially on Safari for opening links in another tab (same as cmd-clicking a link).
So I set up the 3 finger click trigger in BTT, then I assigned "middle click".
It seems to work partially, because I can't feel the click in my magic trackpad.
it seems like a tap, not a click.
I also had a look at advanced options and tried assigning "additional haptic feedback" but no luck.
Can you guys recommend a simple and working setup to get a 3 fingers middleclick with normal click and not just "tap"?
thanks!
