Describe the Bug
When a "2 Finger Swipe from ...Edge " gesture is configured, the CPU usage is very high (around 35%) when scrolling with two fingers normally in any application. This happens also when the gesture is disabled. From preliminary testing it seems even more so.
MacBook Trackpad
( I have been scrolling continuously for about 5 seconds up and down in Firefox when the screenshot was taken. This happens also in all the other apps I have tested)
- Type of Mac: MacBook 13" 2017 Two Thunderbolt Ports
- macOS version: 10.15.6
- BetterTouchTool version: 3.401
This is of no pressing concern for me since I do not use that gesture anymore but I had it configured and disabled and noticed the high CPU usage. I have since deleted the gesture and CPU usage is normal (~3-5%). Maybe this helps someone.
