Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool
and that you have already tried to restart your system :-).
I'll restart right now, I swear. I just didn't want to lose my draft here with screenshots. will update to confirm it persists.
If you encounter a crash, please attach a crash log from the macOS Console.app from the "User Diagnostic Reports" section.
I'm using a keyboard with dedicated media buttons including vol up/down/mute.
my volUP key has been broken for several years and I've had SHIFT+volDN mapped to volUP
I just updated this system from 13.6.x to 14.4.1, and that shortcut broke. The shift key went away from the existing shortcut. re-recording the shortcut gives the same. Using shift with F keys or any other keys works as expected.
I updated to latest alpha with no change.
verified PPPC settings (NOT in input monitoring, removed and re-added to Accessibility.)
I toggled the "higher level modifier key recognition" as well without change.
Watching the advanced actions config output I see the shift key presses as 56 & 60, but don't see the media key presses.
keyboard is a Microsoft Natural Ergonomic 4000 1.0
recording a shortcut shift-N shows the expected up arrow
using shift-volDN gives the EXACT same as just volDN. The modifier isn't registered. other modifier keys don't register along with volume keys either.
- Type of Mac: imacpro1,1
- macOS version: 14.4.1
44660, as well as the most recent release channel. sorry, didn't note that one
