Hi all, I wanted to share 5 presets that I think are good for beginners to BTT. The idea is to start with presets that have high success rate, without needing a lot of tinkering with settings/sensitivity/etc. Once they become comfortable with BTT, they can then dive in to the more advanced presets we have shared in this community
I am an anesthetist, not in the tech industry, so am not a particularly tech-savvy person… so I remember feeling a little overwhelmed with the power of BTT when I first started. Hopefully this helps others similar to me.
Hey, thanks for sharing. I downloaded this and see it in my preset options. I clicked it to be active but I still do not see any of the triggers or action populate in my BTT. Any advice?
Hi Smingle -- sorry you're having trouble. I had a friend download and open the presets and they worked for him. Can you provide a few screenshots of what you're seeing?
I also ran into the same issue when I downloaded it from the link above. Then, I watched the video and downloaded the preset from the video subscriber email, which worked!!
Just so the devs know, that link didn't work either on my system. I just downloaded BTT today and "installed" the presets, but nothing showed under All Configured Triggers Overview. The link provided by @pinkgalaxy did work to load the presets.
BTT 4.478
|Model Name:|MacBook Pro|
|Model Identifier:|Mac15,6|
|Model Number:|MRX43LL/A|
|Chip:|Apple M3 Pro|
|Total Number of Cores:|12 (6 performance and 6 efficiency)|
|Memory:|18 GB|
