Worked fine for 1Yr+ - Now keeps quitting
Hi - I've been using BTT for more than 1 year without any issues. Outstanding app.
However since about 1 week, the app is very unstable and keeps quitting after roughtly 15 seconds, sometimes 30 seconds.
I've tried:
  • Latest version (alpha
  • Rebooting
  • Uninstall and reinstall
  • Disabling all triggers
I'm running version 3.616 1765 it on a MacBook Air M1 8Gb Ram - MacOs 12.0 beta
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
BTT only supports the final version of monterey, the betas did have various bugs. Upgrade to 12.0.1 final and it should work again.
I am having the same problem on high sierra; how far back are you testing?
I have been installing software updates ; however, if you don't continue to work on the older (frankly more stable) operating systems, let me know which version I can downgrade to.
On monterey I'm not seeing quitting. Instead, BTT just jumps to the front temporarily stealing focus until I dismiss it.
