I just created a new feature request for this myself:
Fingers crossed we might see something added at some stage! (though I suspect it would be a fair bit of work to implement well)
Is the HTML button Title effect still functioning? I tried to use today but I couldn't get it to work, I wanted the regular button styling but just bolded (using it to indicate if I have a Long Press Action on a button) I tried this:
<html>
<span style="color:black;font-weight:bold;font-size:15;font-family:Helvetica Neue;">T2-T3 Standby Reasons</span>
</html>
But it looks like the image below:
Unfortunately macOS automatically tries to make it more readable if you specify a full black.
Try something like this:
<html>
<span style="color:#000001;font-weight:bold;font-size:15;font-family:-apple-system">T2-T3 Standby Reasons</span>
</html>
Perfect, Thank you!
Hi Andreas, are you still working on the Stream Deck Feature set?
It seems rather unstable still and I can't get consistent success with actions for controlling it. For example I can set a keyboard shortcut for it to turn off. But the action to get it to turn on doesn't ever work for myself.
yes, just report any issue you encounter. The toggle on/off will be fixed with the next alpha in a few hours!
Hey that fixed by the way, thanks!
Reminders widget custom date format not working. I want:
Tuesday, Dec 12
I've set the custom date to:
EEEE, MMM d
but the date shown in the reminders widget is:
Dec 12, 2023
in some configurations the date format was ignored, should be fixed in v4.344 alpha!
In window snapping please add option to double-click on a window title bar to maximize the window (similar to the option available in BST). This doesn't seem to be available in BTT, or possible to build manually with triggers. This is a very general feature, so I think it's worth prioritizing over more niche additions. Thx!
Hi Andreas, is there anyway to disable shortcut while typing?
for example:
I’m using only 1 letter like “X” for “cut” or “C” for “copy” but when I’m typing/renaming a file/folder with those letters it won’t type them, because I’m using them for shortcuts.
I was trying to 'start fresh' using the alpha - 'sync settings with...' command.
I use iCloud and noticed that, after syncing, there were some things in the 'Recently used' tab that were left over from a few revs back of my settings. Makes me wonder if 'Delete Sync Data' actually deleted it? It looks like iCloud storage has changed a little bit and I can't seen to find any useful location in "~/Library/..." that would seem to be related to BTT?
