Oh weird, I thought I tried that :slight_smile:
Does it work when setting both to zero?
Yes, both set to zero works.
Should be fixed in 3.305 which defaults to 0 - will be online in 5 minutes.
v. 3.306
Todays event missing. start range 0 days - end 10 days, shows event on Sunday and not today.
Ah there was still an old exception for "today". In 3.307 everything is using the new range function.
@Andreas_Hegenberg, Just installed the new options and really appreciate the new options! still a couple of loose ends though,
This issue still seems to persist in the latest update, while for some reason, all calendar widgets seem to only want to display one event no matter what the max is set to...
Weird, could you post your config? It seems to show all events fine here.
I'll try restarting and seeing if that helps
Restarting didn't seem to help...
Oh there seems to be a bug with the "show notice if no events are available" option :slight_smile:
Will fix!
Small request, while you're at that is it possible to have a custom no events message? Not really neccesary but its a nice small touch (and i'm all about small touches)
Ok! 3.310 includes this & is currently building and will be online in about 10 minutes. I'm going to sleep now :slight_smile:
Thanks for the help! It's morning here aha, have a good rest!
Not sure if you changed anything @Andreas_Hegenberg, but updating my secondary machine to 3.310 seems to have fixed the brightness up/down issue?
v. 3.310
Works, have my today events back! Looks like you also fixed the icon displaying on Event widget. Nice work. This calendar widget got very powerful in just a few updates.
Like that idea, custom no event message for the win!
yay that’s great! I tried a few things, one of them seems to have worked :slight_smile:
Would you mind if I propose ⌘[ and ⌘] to "Select Next / Previous Trigger"? I'd love it for grindy batch applescript editing!
They don't work on e.g. german keyboards :wink: but I can add select next / previous to the main menu, then you can change shortcuts via system preferences => keyboard => shortcuts => app shortcuts
Recommended as Photoshop and Illustrator uses those to switch layers
