When I open BetterTouchTool or wake my Mac, the Touch Bar won't run my widget's script. The widget will display the widget name, but it will display the output after the x seconds timer. Always run on becoming visible is on.
Touch Bar
- Type of Mac: MacBook Pro (15-inch, 2017)
- macOS version: 10.14 Beta (18A365a)
- BetterTouchTool version: 2.563
