Keyboard shortcut does nor work.
Could you help me please.
do you have multiple desktops open? (The shortcut does only work if there are more than one desktops open in mission control)
Yes, there are more than one desktops. Meanwhile other shortcuts work. Only control left/control and right combination don't work.
I tried many things, but I couldn't figure out where the problem came from. Also, this shortcut is not working when I set this shortcut in the system preferences of Mojave (keyboard shortcut settings)
Ah that's interesting.
Maybe some other app is "stealing" the shortcut? Possibly try to quit every app one after each other to check that.
BTT basically just triggers the system preferences shortcut, ao id that doesn't work it also won't work in BTT.
