I use the system double click to zoom windows!
System preferences → Trackpad → look for the checkbox There
Thanks, but I mean I need disable BTT double click feature. Or disable the warn message.
I have no Trackpad yet.
Ah, if I'm not mistaking you can just ignore this error message then It's nothing but a warning because your settings will interfere with BTT actions if you use the "double click" to toggle an action in the mouse/trackpad section
It most likely is because you have imported a preset that uses the "Double Click Window Titlebar" trigger in the "Named & Other Triggers" section in BTT:
Yep, I have solved it. Thanks.
