Its still not possible to create a good looking floating menu. Item positioning, resizing, icon changing is a horror. No i cant see the menu anymore.
if the notch menu doesn't work try to toggle it disabled and enabled again (cmd+d)
However this is just supposed to be a basic example, you most likely will want to adapt the menu to your needs.
Resizing, positioning items and changing icons seems to work fine here. Possibly try the live editor if you'd like a more visual preview
