When successively pasting two texts, contents of first text is replaced by that of the second
I have an automation set up that when I press a certain hotkey combination a text is pasted, then tab is pressed, and then another text is pasted.
This used to work, but recently the content of the first text is ignored and replaced with that of the second one, meaning the contents of the second text get pasted twice.
Keyboard
  • Type of Mac: MacBook Pro m1 pro
  • macOS version: 14/5
  • BetterTouchTool version: 4.565
I'll have a look! For now you can probably fix it by adding a small delay using the predefined action "(Async) Delay next action". 0.1 seconds should be enough
Your suggested workaround did indeed work, thanks.
