What Would It Take To Build A “hyperland” For Macos Window Management?
@sid11 what do 1, 2, and 3 represent? How is the Floating Menu configured? Please share your config and I'll try to find some time to take a look.
yep, please describe in more detail what you need, I don't really understand what you are trying to set up :slight_smile:
Sorry for the confusion, so this is how I am doing now:
So this is something that was doing nothing it to command + 1
It opens arc in a certain place that I want...
So now what I wanted is, I want to have some visual idea of like what management is currently I am on... so I was thinking of using floating menu.
So I created these three:
I was thinking if I could put them somewhere on top of the screen, @fortred2 help me with this. I was able to put it beside the notch.
When I click on 1 it triggers a shortcut, i.e, cmd + 1
So it opens the first window layout that is arc.
But I want to control as much as I want via keyboard,
so I was wondering when I press command + 1 can then number one in floating menu, become a bit dull? I'm trying to create an effect, like which one of these three is active.
ICI can map those numbers to some shortcuts, but I'm not sure if other way around is true. If I take a shortcut, I am able to change some colours or something to the numbers...
Basically, I'm trying to create my own virtual desktop environment in just one screen. Using this way, it is very fast.
@fortred2 is it clear?
@sid11 It's still not clear to me. What is the BTT Trigger associated with the BBT Actions from your first screenshot?
It would be much easier for me to help you if you provide me with a link to download your entire BTT configuration in a Preset (relevant docs: Presets · GitBook).
Also, am I correct that English is not your first language? If so, could you try writing in your native language and then I can translate it using an AI? The potential opportunities of this alternative communication strategy is that you could better express yourself.
Also, please tell me:
  1. What is your macOS version?
  2. What is your BTT version?
Okay, so I want this,
When I press command + 1
Color of 1 should dim a little bit
when I press command + 2
color of 2 should dim...
like this.
is it possible to do this?
@sid11 It's still not clear to me. When you say "Color of 1 should dim a but", are you saying that you want the color of the first item in your Floating Menu to be more dimmed than it currently is in your first screenshot? Or are you saying that when you trigger the Keyboard Shortcut command + 1, you want the first item in your Floating Menu to be dimmed just like in your first screenshot?
I suggest looking at each Action in the "Floating Menu Related Actions" section. For example, the "Update Floating Menu-ITEM Properties" Action can be used to update the the design of a Floating Menu Item.
It would be much easier if you provided me with your BTT configuration in a Preset file. You could also copy your BTT configuration as JSON and paste it here. To do this, simply select a Trigger/Action/Floating Menu, copy the selection to your clipboard, then paste the JSON content here.
dim a little bit
yes this one
@sid11 It's very difficult to help you without you providing me with your BTT configuration. There are simply too many questions I need to ask you to understand how you're Floating Menu is configured and what Triggers and associated Actions you've setup. If you provided me with your configuration, it would be MUCH easier for me to help.
  "BTTMenuItemVisibleWhileActive": 1,
  "BTTMenuItemShadowEnabled": 0,
  "BTTMenuFrameWidth": 22,
  "BTTMenuItemCornerRadius": 10,
  "BTTMenuTextMinimumScaleFactor": 0.3,
  "BTTMenuAlwaysUseLightMode": 1,
  "BTTMenuItemBlurredBackground": 1,
  "BTTMenuItemBorderColor": "0.000, 0.000, 0.000, 0.000",
  "BTTMenuItemPaddingBottom": 5,
  "BTTMenuOpacityActive": 1,
  "BTTMenuItemVisibleWhileInactive": 1,
  "BTTMenuAnimateShowDuration": 0,
  "BTTMenuItemAnimateHover": 0,
  "BTTMenuItemBackgroundColor": "168.213, 183.731, 225.311, 29.612",
  "BTTMenuAppearanceStyle": 0,
  "BTTMenuItemBackgroundType": 4,
  "BTTMenuItemsUseModifierModes": false,
  "BTTMenuItemPaddingRight": 10,
  "BTTMenuItemPaddingTop": 5,
  "BTTMenuTitleBarStyle": 0,
  "BTTMenuCloseAfterAction": 0,
  "BTTMenuItemBorderWidth": 2,
  "BTTMenuItemBorderColorHover": "0.000, 0.000, 0.000, 0.000",
  "BTTMenuUseStyleForSubmenu": 1,
  "BTTMenuVerticalSpacing": 5,
  "BTTMenuLayoutDirection": 3,
  "BTTMenuItemPaddingLeft": 10,
  "BTTMenuWindowLevel": 2147483631,
  "BTTMenuFrameHeight": 30,
  "BTTMenuHorizontalSpacing": 5,
  "BTTMenuShowIfWindowLevelEqualsEnabled": 0,
  "BTTMenuWindowResizable": 1,
  "BTTMenuOpacityInactive": 1
this?
Yes. However, what you provided me is not the entire configuration.
Try to copy the entire Floating Menu and then paste the entire JSON here, like this:
  1. Select "Copy" like in the screenshot below:
  2. Paste the content of your clipboard:
    "BTTLastUpdatedAt" : 1756131625.3439322,
    "BTTTriggerType" : 767,
    "BTTTriggerTypeDescriptionReadOnly" : "Floating Menu",
    "BTTTriggerClass" : "BTTTriggerTypeFloatingMenu",
    "BTTUUID" : "9E0BD6B7-4A53-4602-9A67-C7D4B1ECD9B4",
    "BTTEnabled" : 0,
    "BTTOrder" : 4,
    "BTTTriggerName" : "Floating Menu: no-name-9E0BD6B",
    "BTTMenuItems" : [
        "BTTLastUpdatedAt" : 1756131240.5320649,
        "BTTTriggerType" : 773,
        "BTTTriggerTypeDescription" : "Standard Item",
        "BTTTriggerParentUUID" : "9E0BD6B7-4A53-4602-9A67-C7D4B1ECD9B4",
        "BTTUUID" : "7BEBE0C0-0677-4758-AF77-BFBA0A57FD36",
        "BTTOrder" : 0,
        "BTTTriggerName" : "Menu Item: 1",
        "BTTMenuConfig" : {
          "BTTMenuItemBackgroundColorHoverDark" : "90, 90.000, 180, 166.991",
          "BTTMenuItemBorderColorDark" : "255.000000, 255.000000, 255.000000, 255.000000",
          "BTTMenuItemIconColor1" : "255.000000, 255.000000, 255.000000, 255.000000",
          "BTTMenuItemBackgroundColor" : "127.500000, 127.500000, 127.500000, 255.000000",
          "BTTMenuTextMinimumScaleFactor" : 0.29999999999999999,
          "BTTMenuItemBackgroundType" : 4,
          "BTTMenuItemMaxHeight" : 50,
          "BTTMenuHoverEndAnimationDuration" : 0.14999999999999999,
          "BTTMenuItemMaxWidth" : 200,
          "BTTMenuItemResizeImage" : 3,
          "BTTMenuItemBorderColorHover" : "255.000000, 255.000000, 255.000000, 255.000000",
          "BTTLastChangeUUID" : "B4006375-B3A9-442E-BD7C-F397C3E8C087",
          "BTTMenuItemBorderColor" : "255.000000, 255.000000, 255.000000, 255.000000",
          "BTTMenuItemMinHeight" : 50,
          "BTTMenuItemVisibleWhileActive" : 1,
          "BTTMenuItemBackgroundColorDark" : "108.442, 96.000, 190.435, 166.991",
          "BTTMenuElementIdentifier" : "1",
          "BTTMenuItemVisibleWhileInactive" : 1,
          "BTTMenuItemMinWidth" : 100,
          "BTTMenuItemBackgroundTypeDark" : 4,
          "BTTMenuAttributedText" : "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red255\\green255\\blue255;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c100000\\c100000\\c100000;}\n\\deftab720\n\\pard\\pardeftab720\\qc\\partightenfactor0\n\n\\f0\\fs44 \\cf2 \\expnd0\\expndtw0\\kerning0\n1}",
          "BTTMenuItemBorderColorHoverDark" : "255.000000, 255.000000, 255.000000, 255.000000",
          "BTTMenuAppearanceStyle" : 1,
          "BTTMenuItemBackgroundColorHover" : "90, 90.000, 180, 166.991",
          "BTTMenuAlwaysUseLightMode" : 1,
          "BTTMenuHoverStartAnimationDuration" : 0.14999999999999999,
          "BTTMenuUseStyleForSubmenu" : 0
        "BTTMenuAvailability" : 0,
        "BTTMenuName" : "1",
        "BTTGestureNotes" : "Standard Item"
        "BTTLastUpdatedAt" : 1756131244.713068,
        "BTTUUID" : "ABAF22A4-4A66-428B-8F50-D3A07F0698DB",
        "BTTOrder" : 0,
        "BTTTriggerName" : "Menu Item: 2",
        "BTTMenuConfig" : {
          "BTTLastChangeUUID" : "68C0D295-0806-4C4F-8065-7F5458C45840",
          "BTTMenuElementIdentifier" : "2",
          "BTTMenuAttributedText" : "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red255\\green255\\blue255;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c100000\\c100000\\c100000;}\n\\deftab720\n\\pard\\pardeftab720\\qc\\partightenfactor0\n\n\\f0\\fs44 \\cf2 \\expnd0\\expndtw0\\kerning0\n2}",
          "BTTMenuUseStyleForSubmenu" : 0,
        "BTTMenuName" : "2",
        "BTTLastUpdatedAt" : 1756131250.1603389,
        "BTTUUID" : "8111357A-FC6C-43A8-A258-2D52D77D66A3",
        "BTTOrder" : 0,
        "BTTTriggerName" : "Menu Item: 3",
        "BTTMenuConfig" : {
          "BTTLastChangeUUID" : "031C5A13-B5FD-4F62-9B96-AF70070BF69D",
          "BTTMenuElementIdentifier" : "3",
          "BTTMenuAttributedText" : "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2822\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red255\\green255\\blue255;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c100000\\c100000\\c100000;}\n\\deftab720\n\\pard\\pardeftab720\\qc\\partightenfactor0\n\n\\f0\\fs44 \\cf2 \\expnd0\\expndtw0\\kerning0\n3}",
        "BTTMenuName" : "3",
    "BTTFloatingMenuRenderedPreview" : "iVBORw0KGgoAAAANSUhEUgAAAMgAAABjCAYAAADeg0+zAAAAAXNSR0IArs4c6QAAAHhlWElmTU0AKgAAAAgABAEaAAUAAAABAAAAPgEbAAUAAAABAAAARgEoAAMAAAABAAIAAIdpAAQAAAABAAAATgAAAAAAAABIAAAAAQAHvBEAABuOAAOgAQADAAAAAQABAACgAgAEAAAAAQAAAMigAwAEAAAAAQAAAGMAAAAAG1MZDQAAAAlwSFlzAAALEwAACw0B1NujxwAAEXhJREFUeAHtXelzE0cW7zl0S74PLCMj24BZHG5jkhTJUqSoclK7tV_3y_4v+V+2+JJv1FZlCxKyUAsLgWDAwQfGl3zbsmVZ9zGa2ffaluJTki3Z0livq2TP0T3T83v963d0z7TA9k03DG73qhStqpJsoZC8bzY6QQjoFIGw3a5YAoHU1FR9irE3yb0eQ9h98I7c3e2tSon2dkkQWllKrVGZYN+dj44QAvpGQGRaiEmiP6Vpc5IamhwcbAww9kTZ+lTbCNLd3W3UZEu3lpI_FwVWz5gmQFIhaX8UEmBb_WOXtnYgIMK+tg3XHRl27BKeOwDZY_egmO5xiT0OiaIoaJoGFxc0aOGrgqS8FJToIKREOvsW0+mOrCixm5KgfS2JTISCnEnwnwFJID8KEpIIpNGMosEggoIRsOaUAAHASUulVEVVFdgSQWVjykUULMVATkZBkgRRkkRpoxz9RQQAz1QqBW1XS0CPLODvAB1PbgwRfLwNyAkUiVCnpqQ+RXFYGbvza1qTZG54+XLPZ4oq_RVLQDW2aAx+BPY1wWazmFtbmlz19fVOq83SbDTKZqg9ZqjoJDKBKUoqHg5Hlld96_MzswszwVAoAu2d47Y3OAL0NKJ86hSA2dLodtgdTSaTsY5RlwMQCEwFXkSjCV8oGFqaX1z2LC2trWpaEhpzcUmyVTaoC3BfFlP_Ghj47QNu8wONjd32hmbHP0Bz1AGrNns_PI0J1I+qMqezqenyZ133amurukRRMm6co787EQCslEAgNP7hw8dHnrmFOVDGkGWnJtE0o9FkvHr5Yq_L1XzbYDDUbGjpnVejfU1TWTyR9M1Mzz19NzDarygJcKaPjiQgBymlMt_KUvCfXu_gRnTK6bSeURRWD+TY5qCgeND_aGpqaLh549LfHQ67U4GM+KO0NwIAsIydyI0blwBP4f7U9OycLEtbTCdAWZPEnp7uu65W5x28CtgRe1+MjnIETEZjXWen+2+SJNte_DrwiyiiT3w0JEEFAV5EPXLC62WDXKFHk1Ib+ha75SFo4MeI16509TkcNmcymURbe3c2OpJBAPFJJhVmtZobLl069xeLxQja9g_QEkktdeFC+wUgx23Mi9qZUnYENjsQ8cyZ03_uPNvWmUgecY8CXOCcgGpxgshSqg56vl2SAnWmnT7d0lpTU_MnsLGzPwWd3YYAkgQ0bkeb29WeSCib2AqaLAlS+xnnLfDMZepstkGWdQc7ElkWTR3tp3tFbo9uBo2yljrcSeQCcgJLA0G+h3Cw5EBTaufllJSQam6ud4GJQMLcCU4e+xKwobm+9gwEMjhBVDXJwPxymC1mJ2mOPADckQWiWsxuNbug47EdJX6cC8AJ5AbXIDvqsWVXZQ6btWXLAdo8CALQ59js1maMt2MxRdFUiFbVmAwG61EK+CBV1FNe1LgQ0LBXV9vsgN8ui+coniUHQRgzGA2Wo7hxJVwTVbJBlm2ZZ8URJKNsEERhi9OeOUsbORBAgoD5YwRn3ZAja9FO5yQIVGqX6VW0u1fAhQg_fQs5J0H0_XhUe0KgMASIIIXhR6VPOAIngiBkBRavlRKW27HcMllx+wk97fGwuJ4qXIZ1TRMjjeXO_TKs8rFUSdcEwUifw+FgMJDJlpaWYAQ7iVGOYwHuJN0EySDLMquurmZms5mP7kejURYKhfi0okrGVJcESYfAYXyBXb16lV2_fp3dv3+fraysEEEOyFwkh8lkYhcuXGCXLl3iHQ7iu76+zoaGhtjIyAhLJBIVi6uuCILCxN7MbrczI0xxcjqdrKenh2sQCeYDps2CA7aRis2OeCEZLl68yPr6+lg4HGYzMzP4ggpra2tjbrebnx8YGGCIbyUmXREEBYTCQ1K0trbyn9VqJWIU0HItFgv78ssv+RUePnzIRkdHOcaomb_77jt28+ZNrkmQSJVoaukqioUCwp_NZuNCxN4OTQFKh0MANQhqY_ThPB4PGx4e5hdCX+7Dhw8sEokweDmOa+vD3UH_pXSnQXDq888__8xVPr6Xgr3ctWvX9C+JEjwBdjaIJxJjYmKC1yBtxmLwAx13dNQxTyVqDwREdwTBSmMPh44jEiTtsONxSgdDABs9auAHDx5wMxXN17SG7u3t5c77+_fvOdZ4rhKTLgmCgkJBVmqvVuyGip0Mag7UGGhS3bhxg0cHZ2dn2evXr4t9O11dT7cE0RXKZV5ZJAc662fPnmW3bt3iPgmaXE+ePOGh80rVHig2IkiZN96jrh6SAyOBX3zxBdcc6HO8ePGC9ff387BvpYZ307gTQdJIVOB_JAcmDOUiQcbHx9nTp0_5WEjahEXzizRIBTYOemT8lITGGhsbOUFwkPD58+fcaa+r469jc4iQIKhVMG8l+ny61yAoOIpkHY7uGL51uVzcxAoGg+zzzz_fpi2QEH6_n_30008V+6knXRMEVf_Y2Bgf0MJBrUo2BQ5DEfQv1tbW2LNnz3jxvfBDzVKp2gNB0T1BPn36xG3nSh7MOgw5sAwSAmcjzM3N7XuJStfQuiYIShXNKzKx9m3fOU8Qftkhqszh0eyY0FlCIIMAESQDBW0QArsRIILsxoSOEAIZBHISBGc8ZXLTxiEQIPgOAVrZFMlJEFjgZ8_FDcvmCcq4IkgN+CzvtrUiUuAVQ2SIPsZ3SLkBdIAgRGaOKeUkSDQaWzumupzI28RicZ+Kq3xBwq+SxyKxMK5GVYmj0oUKGDGDDiYSDceisDDRsajmrASBOLng9wVnkbUk0EOIF77F6_MHYAVVXIoNCCKL4tp60B+PJ3yE58HxxHGbeCzuXQ+GgjCCV3qCwMJI4vziwmwkEvVufqD84E9VoSVQmPDpHP_i_NKkYNj4WDW+jhSKhOKrq_5hOI9LCFcoOgd_7E2sVK93bSieSCQRy4Nf5eAlcmgQQVxdCwQ80_PPk0k1XOlTn_OFF8kBZnJsbn75xeKybxXWyskIE9cs_DQ+3Q_rGE6i0IkkuVFN4+RfD459HPcMwPrKWdtt7ivmnyPnSDraesND4+_MJpMNFvK8Dp_vb0Cxkpe5L8garC7lX1xcfTs0+Ok1jPNrYA1kBAqLEUmLi8srHz9OPO7q6lBg5WA3EIoWRd0XTj7rOB4IBCdGPo4_8fl8flmE5WaPKeUmCHiWkUQ0_v73of9FY7G1xsbaTovZUitLogPqaaB4zMZykhCbglfk1WAkFl1fW_VPfPw0MRSAdaH3Eib4IsLoxNR4PJlMtLlaLlZX2U_B664O0NCwRjclNJ4w0AdrpIehswn6A8GF6em5wZmZhfm98DxKxHISBG+OlYpE4vGB30fe19VUT1bV2GtsFqsDhHpsC5kcJQjFuHYqpSjBaDQY8of9q2tr6wos9L2fMDfsZ0Gb9MxMe70ry3V1tXVVdpsDVoa20rjThjSAIFo0Hg+HwuHg2orfF4pF4_vhWQz57XeNvAiChcFJ53b0is+_Dj8_HMrY1ftdvAKPo+UpoA8ibyyQngUCTQCBC5FIMh6JLM5juSyZK_mUho2vFORA0PMmSFpCnCiqCkvi4oANI1ckAwwTuK8B5AADIX00538MZm0YaTmzVmoGwCd_PIsN0oEIAgNcKZC_YLXazHb4IxlEMrE2JQL2shIMR8LRcDCmKIJqhJX0ii0sut7xI5A3QZAcLleLs93tumi3W1rA_agGRz3v8sf_aMd7R1iiGLwQZT0cji5NTc8NT03NTmPE6nhrQXcrNgJ5NXAgh3rl0vkrHR3ur81mI7zRL5hA7eVVttgVLtfrYdRFFC0tjip7R11d1cX62upn798P_wZR8mMLSZYrNnquV85Gjpqj65z73Llz7X2w5AB+7kLAxkBpOwI4mAW4QABXkGERGmtn55l78VQy9mFg5HfQtqRJtsOlm73svRt44VaryXy+q+Ou2WyqhwZA5MghWuw88GcwSDVn3W13a6ocDpy_m6MYnS5TBLISJKExpbW1xeWw286AjV2mj1Ce1QJSwDIN1pY292l3Ar8oQUmXCGQliApfUW+sr22FuH5OU0yXT3_ElQbcxNrq6jawr0iDHDHWR3X5rATBKVd2h7WRJtQdHn6bzdwE7KBBwMNDWNKS2QkCVYMgDESsKB0GAfRFQPnSWNFhwCuTMjkJQn1fYZICJUzaozAIS1o6N0FKWj26OSFQWgSIIKXFn+5e5ggQQcpcQFS90iKg2_AtOsBbv_5CrwOXtiGd1LvrkiA47oZrpTc1NfH_+In+paUl_EgCRI1IKZ7UxlqK59IdQVBr4GKTd+_eZbW1tfyjB6hN4F1l9vjxYzY5OUkkKUVLOqH31FV3i0Soqqpi3377LWtubma4hvePP_7IhoeHmdPpZH19fXy1pBMqK3qsEiCgKw0C71uwzs5O1tDQwF6+fMmXBsNR_pGREeZwONj58+e52YVLGOOa35QIgUIR0FUrQjIgEXA9vaGhIfjqRYqbWPF4nMViMb4NU80LxYTKEwIZBHRFEIxUvX37lmsMXFvPZDLxn9vtZh0dHczr9bKFhQXyQTLipY1CEdAVQVCDYMQKf2hu3b59m_X09HC_A17m4k46rspKkaxCmwWVTyOgKycdK42OOv6QBBi5Qn9jcXGRm1e4jHFrays_n35A+k8IFIKAbgmC2mR8fJw9evSI_fDDD9xpx8hWb29vIXhQWUJgGwK6I8hXX33FvvnmG4YmFZpZSXipC02u_v5+PrKOJKEI1jYZ004BCOiOIO3t7QxNqZqaGk4O1CRIFIPBwM0u_jW7TTOsAFyoKCHAEdAVQZAIHo+Haw_UIi0tLXy7ra2N3bt3j_shY2NjnDAkX0KgGAjoKoqFYd43b94wl8vFp5vg6DmaV3a7nVksFj6i_urVK65JULNQIgQKRUBXBMGHjUQi7MGDB6yrq4udOnWKh3hRq8zPzzPUHjhhkRIhUCwEdEUQ1AoY4kWtgQOGqFHQIUfTC0fV0yFg0h7Fah50HV0RBMWVJgmSAR1yjGKlE54jcqTRoP_FQEB3BMGHJhIUQ_R0jXwQ0FUUK58HojyEQDERIIIUE0261olDgAhy4kRKD1RMBHISBD6bSd+VLQBxCCYQfgXgV+qiOQkSCcdWS11Jvd4fgwmxWNKr1_pTveHTu9lAgCnlwnogMEedYDaUsp8LBAMLEI4mLZIdprI9m5UgsMSeND09PxWLxf2SlDVr2T5gqSoGfQtLJBJhz9TCqAyr6ZSqHnTfwhDI2upxyWffWiAwNTX3CCfI0vhDfmAjTgIsTeiZnnsyt7Tsg3XZsuKc31UpVykQyCk4o0GW37z78Nbjmfs3CD5pMMg0GXAPSSEp8C3HzXdR1JmZxf+86R96bjaS9tgDLt0cymskXQLBv3z57r+ra76FzvYzN2Hm7GlY4rgKGoRM_klm+ksKTKpANJ6Y93hm3wwPjw_DGfQ9aFqxbuiwu6J5EYQXA10zPOwZHRubmaitrbI77PZqE3SPMB2q4hOq4YSSVILB8LrfHwolk4kkmKdwmNYG0XvjyJ8g8KSyLIigMVTvynpgZcXvV9UU9Y6bLUAUJRgwEgSMZWyQQ+9Ng+qPCABBvlcFoTcATiUu85wXKhsBLQEtrLzyUyZCQE8I4PAG6IEAcgOtA5bShBUgB9_W04NQXQmBo0AAuYCcwGtzUhgEcZqp3KE8ivvRNQkBfSEAXOCcgFpzgkSjXlgzQFuGUCUNaOlLlFTbIiPAOQBc4JxIEwTe5Y4zVfwFZkSo4IaQ411k0Oly+kAA2z5yALnAOQHVzmgMr3fW11DvikBw8iz4KHg8P49dH89OtSQEsiKAmgNni2gp4eHQ0MvBdOZd2uLCld7zkircgfGtJozjQ4K5djTZLg0Y_T85CGxEqzA4hf63tpwStScj71+Nbn3CXQTBk93d3caE4Og0SmobUxmEf1nV1kK0TQicBARgdlAAvPDVREqcNmrB8cHBwcTO59qTIDszwT6FgPcAhQ7pHoGc80D+DyoVw9gB3oaEAAAAAElFTkSuQmCC",
    "BTTMenuConfig" : {
      "BTTMenuItemBorderWidth" : 2,
      "BTTMenuWindowResizable" : 1,
      "BTTMenuFrameWidth" : 220,
      "BTTMenuItemPaddingBottom" : 5,
      "BTTMenuItemsUseModifierModes" : false,
      "BTTMenuFrameHeight" : 300,
      "BTTMenuItemCornerRadius" : 10,
      "BTTMenuWindowLevel" : 3,
      "BTTMenuElementIdentifier" : "no-name-9E0BD6B",
      "BTTMenuItemBorderColorHover" : "0.000, 0.000, 0.000, 0.000",
      "BTTMenuItemShadowEnabled" : 0,
      "BTTMenuItemPaddingRight" : 10,
      "BTTMenuHorizontalSpacing" : 5,
      "BTTMenuItemPaddingTop" : 5,
      "BTTMenuShowIfWindowLevelEqualsEnabled" : 0,
      "BTTMenuItemBackgroundColor" : "168.213, 183.731, 225.311, 29.612",
      "BTTMenuItemPaddingLeft" : 10,
      "BTTMenuItemBlurredBackground" : 1,
      "BTTMenuCloseAfterAction" : 0,
      "BTTMenuItemBorderColor" : "0.000, 0.000, 0.000, 0.000",
      "BTTMenuOpacityInactive" : 1,
      "BTTMenuVerticalSpacing" : 5,
      "BTTMenuOpacityActive" : 1
    "BTTMenuName" : "no-name-9E0BD6B"
i tried, this should have worked, but can't select the option
"BTTLastUpdatedAt" : 1756132809.093744,
"BTTUUID" : "388B9302-602E-49B4-9F9A-7F55968DC3A8",
"BTTOrder" : 3,
"BTTTriggerName" : "Floating Menu: no-name-388B930",
"BTTMenuItems" : [
"BTTLastUpdatedAt" : 1756132741.5562959,
"BTTTriggerParentUUID" : "388B9302-602E-49B4-9F9A-7F55968DC3A8",
"BTTUUID" : "2844E3FB-1B32-4E40-A52C-4E5B50DAD754",
"BTTOrder" : 2,
"BTTMenuConfig" : {
"BTTLastChangeUUID" : "DC12730D-4609-4AB4-BFC6-3039D029D9FE",
"BTTMenuAttributedText" : "{\rtf1\ansi\ansicpg1252\cocoartf2822\n\cocoatextscaling0\cocoaplatform0{\fonttbl\f0\fnil\fcharset0 HelveticaNeue;}\n{\colortbl;\red255\green255\blue255;\red255\green255\blue255;}\n{\\expandedcolortbl;;\cssrgb\c100000\c100000\c100000;}\n\deftab720\n\pard\pardeftab720\qc\partightenfactor0\n\n\f0\fs44 \cf2 \expnd0\expndtw0\kerning0\n3}",
"BTTLastUpdatedAt" : 1756132741.5563378,
"BTTUUID" : "7C7FBA94-6AF6-4CAB-8293-A5379A236472",
"BTTOrder" : 1,
"BTTMenuConfig" : {
"BTTLastChangeUUID" : "05339105-2383-4DD3-A31A-2C1D7BA8293E",
\expandedcolortbl;;\cssrgb\c100000\c100000\c100000;}\n\deftab720\n\pard\pardeftab720\qc\partightenfactor0\n\n\f0\fs44 \cf2 \expnd0\expndtw0\kerning0\n2}",
"BTTLastUpdatedAt" : 1756132741.55632,
"BTTUUID" : "A53201E3-A715-4EAF-9527-C355FA532CC8",
"BTTOrder" : 0,
"BTTMenuConfig" : {
"BTTLastChangeUUID" : "33BFB9EA-677B-46A6-939C-A66AA5941F78",
"BTTMenuAttributedText" : "{\rtf1\ansi\ansicpg1252\cocoartf2822\n\cocoatextscaling0\cocoaplatform0{\fonttbl\f0\fnil\fcharset0 HelveticaNeue;}\n{\colortbl;\red255\green255\blue255;\red255\green255\blue255;}\n{\*\expandedcolortbl;;\cssrgb\c100000\c100000\c100000;}\n\deftab720\n\pard\pardeftab720\qc\partightenfactor0\n\n\f0\fs44 \cf2 \expnd0\expndtw0\kerning0\n1}",
"BTTFloatingMenuRenderedPreview" : "iVBORw0KGgoAAAANSUhEUgAAADUAAADICAYAAABI6qm3AAAAAXNSR0IArs4c6QAAAHhlWElmTU0AKgAAAAgABAEaAAUAAAABAAAAPgEbAAUAAAABAAAARgEoAAMAAAABAAIAAIdpAAQAAAABAAAATgAAAAAAA_8vAAAOdgAAAEgAAAABAAOgAQADAAAAAQABAACgAgAEAAAAAQAAADWgAwAEAAAAAQAAAMgAAAAAUz304AAAAAlwSFlzAAAK4gAACxMBeCNdEAAACzlJREFUeAHtXWtvG8cV3Znd5UOkKIqkXpYj27JsK36gtpQIcZsUqR2kaICiaIEAbfMb8h_yH_KhgD8UBfr42KAt0KBokrqGWycqZMRwZMtK5FhSIdsUKetJSeTuTs+lRGFNrKklKZEjdQamOTvc3bnnnpk7Q_tcrqYdwsJ8YGIjI1cTOavQyQ2WMjWWdBymM6YJH9fWfYoQGuNc2AVNZB1LZFoMMz06+ukCbvzC_iuCGh6+MqTpYtARrA83MTTOOBOC121pDTcQjDmaIxxcasGIGc1mE2Njn932upUnqHOXLycMK_SWwfmgEILOsbwubmKbwRgTluNMWMbGJ+O3bhFzO0XfqW1Xzr36ZndIC77LNH4cDBMY8s6uxXGEsB0NPhCo7Xux0Z+NjjqZxY9zYc6sri7kSkY+x9SFC6+360Hjl5zzFE7wxY5tO7ZlC6clHAhFo+FIKBhswfWl++_7u9CEETCM+c5U9FfXrl17TB0arl65Hg68xTXeAXIKrnbPKjGjIVj09nYe7e_rGQ6HQ12BgJEwTbMNQ8Pzmv1qNAxDy+U2zv7o_fff+jDDzd3QF0Y_v45JtigxnYHZIGecCgUGro4eLWro_01MFMcxo5THH80BvfLfs_75vN5zTT1dy61tr77sab9bsulH3zAL_71nz_nGjuNqyqyRIDaYtHoa6+c_0UsFjmBw4aD8EIGtuzNfP5vhq7_tOjhkZyecIR2xc_awwyDX371_M_a47EzlmV73b8pbRglHAyl1tftj4ozet22MY+em1+ehm3m7cJ3zp0cSbS3XbAsX3HE8z770UjzGK9gobBxqQgKf6U4FtZKnVFgiLQEw12p9uFGz5lKdrk_w9TWzaBxugiEGSwJQyuGLCzmojMV7wgGAz0UEGQsus550DRfKkY_pul4dyqCAiYn3tbaqes6dkqNjW5+HUhDEJE4UHHIuW9GCyyiXW8jF1Z3_37rAOZ_c8qwmwwEzAh5Q_bimykCglEn57gr83JVoMqulfZQgZKWmjLDFFNlDpH2UDElLTVlhimmyhwi7aFiSlpqygxTTJU5RNpDxZS01JQZppgqc4i0h4opaakpM0wxVeYQaQ8VU9JSU2aYYqrMIdIeKqakpabMMMVUmUOkPVRMSUtNmWGKqTKHSHuomJKWmjLD_r+ZgpCVb6xvLMgqDHGT5ZspDq3B4srq44MAakfv50bqVYckmD9bXE4DVAH4TK9zmtlG+o6SEsc3U9DR8XR6MbOytv6QlJAyF9+gCIRtC3t29um_ofPLy6x8qQqUaXLjwdTMg7nH6RukUZIVWFWgiC2kDuhjX05cn5vL3AAoG6oyapaqFC3qOdp_FtOsC5btKuQDEEaCxunZp18jdmQjLaGkaRqtNM+IuWa+YINj2_a9mmY8VJxYtpj+1f1vvnz47ez9vmM9A_F4rCfaEu4JhwJdAFb1CNgLqiFStizHXq4JVMkAMGRsFixr4sGjcU3j96BvxFRrjnaOVPJIdGEOM+7UBYrAbbEmV4xvyjApMb1f74cSVN3Dj7xN0RDFIZ0t_t41gu4XQxBs61rQtuoCBSyUkuMg6rUkEvFUIhHrQojvhJKa1apLLe3fagGOnRzlH5k1gyog6rW3xeJnTvUNJTvahwKGHkMoDyAiwp7miIexTllIZpmtCRQB6j_ee_LsYP+PkTPVTTkf5GF64bNanFz3NbToowh8i7CrBkWABk4eHTj_8sB7YCWcz1dM4qnb2FpuUFX0o0CQwswZPHXiJwQIW5Ja+tz3a6oCRUHh5dN9r0ci4Q5ZAZHHfIOisJ1KRNuQN3VetjSjcup9zylah5LJeAfS5GJ0k+2JWX6_ph6XbPLN1FbaXmv3dvphU43frXPfoChWRqMtPfSNV_ZSlYUAJN_XXA8PVwXK43opmxQoKWnxMEox5eEUKZsUU1LS4mGUYsrDKVI2KaakpMXDKMWUh1OkbFJMSUmLh1GKKQ+nSNmkmJKSFg+jFFMeTpGySTElJS0eRimmPJwiZZNiSkpaPIxSTHk4RcomxZSUtHgYpZjycIqUTYopKWnxMEoxBTWfnLqdMrZ8M0WS39W1tScHIYHFNyjK9VhcPhigfMt4IJHh2YXFNKRxK1CQtdajoCwbLXtySBKekk2+mSKpdiazvPRsaXn8UGXl6IbOJyZnb67l1rMy5niUKPfNFF1gIENgfj6bmZyc+RPkcZuyAqsKFAHDfDImp6Yn745P_X5jY3MevyK8nbRCn8pRfAcKt7kE7JuHs5OYX78+fbLvFegAhwIIHpismG6UnYOza9Vwuzuqsm6YBjKGHPr17doKAVt4trp0a_Tu31tbo7dSyXiqvS3aHYmEOhFUeDNA4efSHejSH9QMilxBcwy_Ss5zufX16bXc9JQtvm1mBoFtY4dgsq_qAlXimMI9BKgUN6AHbI4k0JVqZFQdKEpAZH4_lKDqHn4k7YZGnXbv2EjRH3oSRTMKxwOBkPepMVEXKEqRCAWCgf7+3oH2GHISo+EjlJOIRLqGA6MsSIPrJMr+qCZQW+wI59zgifPH+o68GQoFjtL6RBvK0qayGVzhOT0FZOXEawBFqVFCuzxy4e0jPck38I3EoKycZmcV0C59+7ueU3WgKBQK9qWLZ753tLfjB2CjCKgZrFTqsypQhYJjnRo4duqlI91XySvNHGp7Bgp5vPqxl7q_i3yPoKyACKxvpiisdKTiyWgkPNDs+VOJJfrMd6CgvNBkewyPleHS_cBGCSQFCyq+mcIaK2Kx6OFKYKGsHDy3LXnosnJKNMv+7nv4yQ7EbZ8C5faGzHXFlMzsuG1TTLm9IXNdMSUzO27bFFNub8hcV0zJzI7bNsWU2xsy1xVTMrPjtk0x5faGzHXFlMzsuG1TTLm9IXNdMSUzO27bFFNub8hcV0zJzI7bNsWU2xsy1xVTMrPjtk0x5faGzPWqmML_6DdcHVaL83yDEhpnhby1JrPSpeQA36BIBLy0sja3rdQqXS_lu2_FC0kuF5eWn0KGiZ8l35aWSASJTCqNIt9MkYw0k13MbOQLT2QXiPgHBX3syupmLj2_cJu09DKXqqwLBnTzzr2HX2SfLUqdblQVKGIHIlXr9p0Hf1lZWZsxjOYI63cbJVWDojS+paXVpZuf3_nt_PziGCaoKKYOkHhakvhRdHU1z8ohL1GCSr5g5adnn0zk1ja+NszibSxg4lA9B4GbROo4r3EvciiSavCsHKe2Z+UUgZHV2F9M__fJ9NSjuUfIxgnFopFouCUQQQeQHu82SPb2c4pdDlypC_G573XqRSaAFYw+ruFZBIV0dmFBzIsszm1C9hQ6ZUgU0nimCEpotoVtXV2GUGYO8o5Yk5Jyij4XGDscEtJioBCWyGLE1AXqRUw2sp1B5+tofKEICsM_g1SHBs+CvYeLpAwbILJFUGFdn0cXzXnKyJ5hI070QotuZIqgRt9545lgYgat0sqzd8OO6cPB1OytH15e3NoSXL8uOrr78I1JP4NgfCDnFr46WAD1r6d+E26yBR54e7YjXGwNYGl9QCyxU18HZq4859_3CcsO6BQd+z1_CeOY9H8qnv9ops3qBhFm_P2dfRXDHbP7UjT6ZmNZO_xWZPzY8CLh5LIHhGRAMu0+bwm_nj39vVMyYnPgaLG+blHq4m+7inm6K14OFYnmugc2cK9QVsxPI_ofl5f__P4FzdpdO2Uiv86NDx8ZUjTxaAjWB+uMBBJ8AiwrQV75w4NqmDOONrWWmrBiBnNZhNjY5_d9uq+IqjtC9jIyNVEzip0coOlkP6fdByGp3U2JkpuJyXbBU1kHUtkWgwzPTr66QJsO5BR2osEX23_A7PDEWzcE5QTAAAAAElFTkSuQmCC",
"BTTMenuConfig" : {
"BTTMenuItemBackgroundColor" : "168.212997, 183.731003, 225.311005, 35.656091",
"BTTMenuFrameHeight" : 61,
"BTTMenuOpacityActive" : 1,
"BTTMenuFrameWidth" : 369,
"BTTMenuSelectedTab" : 0,
"BTTLastChangeUUID" : "B393158D-1B36-45B4-8AC6-07E79C27982B",
"BTTMenuElementIdentifier" : "no-name-388B930",
"BTTMenuAppearanceStyle" : 0,
"BTTMenuAvailability" : -1,
"BTTMenuUseStyleForSubmenu" : 1
"BTTMenuName" : "no-name-388B930"
@fortred2
@sid11 did you modify the the JSON in any way? The text you provided me isn't valid JSON. I had to modify it by adding indentation. I then pasted the updated text into BTT, but the generated Floating Menu looks broken and doesn't look like the screenshots you provided before.
I delete the old one by mistake :frowning:
I am so sorry...
But were you able to understand what I want to do?
I still don't fully understand. I think I have an idea of what you're trying to achieve.
I'll ask you a question I asked you before:
What is the BTT Trigger associated with these Actions in the screenshot you provided?
