i cant find what is it or what its functionality nor in the forum or the docs
it basically runs the script once everytime the widget is rendered to the TouchBar
so this essentially disable the "execute script every" function ?
it’s in addition to that (to disable the execute every xxxx, set it to 0)
i think in that case the option is redundant because the widget will run/stop based on the group activation condition.
okey i finally got it after some trail & error, it essentially runs the script once it became visible without having to wait for the delay seconds to pass, regardless of the delay timer.
the reason i was confused is on some of my scripts it was refreshing the script very aggressively despite the 10 seconds timer.
