Quick question: How do I pass my location to Dark Sky when I click on the weather forecast?
Details: The weather touchbar is working properly and giving me the correct forecast. But when I click on the forecast tool, it gives me the default Brooklyn, NY weather report. Nowhere near where I live.
I have location services enabled for BTT. Any ideas?
Hi there! I've been using AquaTouch for a couple of weeks and has been awesome, thank you!
I have one question, can I change the units of temp. from F to C?
yep. on the strip on the left, click Open QuickControls --> QuickSchedules then click on the weather widget at the bottom. now on the right, find the button that says 'Unit' and select Celsius.
