Weather group doesn't work
Shows night weather icons no matter what the settings.
The servers all seem to be available and it works fine here, do you maybe have a firewall that blocks access?
Did you provide your location manually or are you using auto-location? (in that case the permissions need to be set in System Settings => Location Services
All permissions given to btt as directed. Not working.
You can see that the settings are correct and that weather shows night time icons during the day.
You can see that the settings are correct and that weather shows night time icons during the day. Notice that the local time is 10:05 AM.
Screenshot 2023-10-05 at 10.17.02 AM100%75%50%
Screenshot 2023-10-05 at 10.05.20 AM100%75%50%
Screenshot 2023-10-05 at 10.04.47 AM100%75%50%
ah maybe some icon is mapped incorrectly in BTT, could you check what wheather condition is shown in Apple‘s weather app at that same time?
