I'm having an issue where my Volume/Now Playing widgets will vanish and not reappear without restarting BTT. If I run the scripts from inside the BTT script editor they work fine, but for some reason they are vanishing otherwise. I'd be happy to send you the scripts/my config if you'd like!
Touch bar
How it should look:
How it looks:
- Type of Mac: MacBook Pro 15" 2017
- macOS version: 10.14.6
- BetterTouchTool version: 3.202
