Downloaded and installed 3.540
1 finger tap middle top for volume up or 1 finger tap middle bottom for volume down no longer works properly, it only decreased or increases by one step and have to wait several seconds to do it again, the old versions worked fine rapidly, please fix as I have to downgrade until this works as this was my most used function for the program.
Seems to work fine here, could you go to Help => Export Diagnostic Debug Information and send the result to andreas@folivora.ai referencing this thread? (Then I can try with your exact setup)
ok thanks I'll do it soon when I reinstall newest build I've downgraded to second to last version and it's working but I'll get that done.
edit: I reinstalled newest build and it worked, was probably an installation kink, all good.
