My preset crashed and had been wiped from within preferences displaying 'You have not yet configured actions in BetterTouchTool' so I went ahead and tried restoring from back up but I was getting the same issue. Then I checked for updates in both BTT and the GoldenChaos preset installing both from scratch. It seems to install fine until I click one of the modifier keys such as command/alt which then causes the error to happen again. I have tried updating to the latest alpha version of BTT and the latest preset for golden chaos.
I have also tried running tccutil reset All com.hegenberg.BetterTouchTool in terminal but still nothing, I did notice that when importing a preset the name of it isn't displayed properly. Image posted below.
TouchBar but does appear to wipe everything from presets.
MacBook Pro 15" 2018 touchbar
Catalina 10.15.7
GoldenChaos 3.392
BetterTouchTool 3.506
I have no idea how to export the console logs correctly but I have attached an image below, cant upload a text document.
