So for years I've used BetterSnapTool for my Window management. One of the hotkeys I used was CMD-Left and CMD-Right to make a window appear on the left or right half of the screen. When I used CMD-Tab to change apps, I could still use CMD-Left to go to an application left from my selection.
This functionality does not work in BTT. If I use CMD-Tab and then use CMD-Left to go to a previous app, it just makes the current window go to the left (as I set it up in BTT). Is there a way to make BTT deactivate some Hotkeys while using CMD-Tab (just like BetterSnapTool somehow does)?
I hope you could follow me I appreciate any help!
Sebastian
