Hi all,
I have been happily using Bettertouchtool for months perhaps years (time flies!) with my MacBook Pro. However, last week after doing a BTT update, I starting getting occasional notifications that a usb device kept disconnecting. At the same time I noticed that I was often having to click multiple times for the click to be registered, which got very annoying. So I googled this error and saw advice that the usb hub might be an issue. With that in mind I ordered a new usb hub which I installed a couple of days ago. Unfortunately this has not fixed the issue. I also have a bluetooth trackpad which is working fine.
This issue has rendered BTT unusable for me, which is a great shame as I use it primarily with Cubase and it is a massive time saver. When I use the MacBook Pro on it's own, everything works fine.
Are there any suggest fixes for this?
