Updating reusable named trigger's name issue
Hi.
So after updating some of the named trigger's names (in Automations & Named & Other Triggers tab), it doesn't auto-update "actions executed on trigger" that were using it AKA they're still using the old name so they're kind of "broken" due to the different/updated name. Currently, what I do is go to that action and update the trigger name used.
Is there a way for this to be automatic or is it a limitation? Thanks!
  • macOS Golden Gate 27.0.1
  • BetterTouchTool v6.931
This is a limitation / design decision. A named trigger doesn't know where it is being called from (scripts, triggers, cli etc.)
The only option would be to export your preset to JSON and do a search and replace via some text editor.
Understood. Thanks!
