I have a general short cut for moving a windows on the other monitor. It's work fine except with VLC.
I had worked before, I don't remember when it stopped, but it should be about 6 months ago.
Keyboard short cut
Global configuration:
VLC Configuration:
- MacBook pro 15' 2017
- macOS version: High Sierra
- BetterTouchTool version: 2.605
